hdroyer Posted July 15, 2007 #1 Posted July 15, 2007 I removed the rear wheel and put grease on the drive shaft and wheel splines. I could not get the hub off I removed the retaining clip but still could not get it to come off, I did not want to pry on it for fear of damaging the hub or the rubber seal. Any ideas? Dale
Denden Posted July 15, 2007 #2 Posted July 15, 2007 The hub has 6 "pins" that fit into the rubber snubbers built into the wheel. Each rubber snubber has a steel tube center, that the pins fit into. It can be difficult to get the pins out of the snubber tubes, there will be some corrosion. Try some penetrating oil, let it sit for a while, then gently pry a little at each pin. This link is from the 2nd gen tech library, but the 1st gen rear wheel is exactly the same. http://venturerider.org/forum/showthread.php?t=1705
hdroyer Posted July 16, 2007 Author #3 Posted July 16, 2007 Denden said: The hub has 6 "pins" that fit into the rubber snubbers built into the wheel. Each rubber snubber has a steel tube center, that the pins fit into. It can be difficult to get the pins out of the snubber tubes, there will be some corrosion. Try some penetrating oil, let it sit for a while, then gently pry a little at each pin. This link is from the 2nd gen tech library, but the 1st gen rear wheel is exactly the same. http://venturerider.org/forum/showthread.php?t=1705 Thanks, for the info Dale
