I have a complete Kit boxed up and ready to go. This Kit sells for $44.95 and contains everything listed below.
Donate $30 to this Site and I will ship the Kit to you FREE anywhere in the USA.
Confirmation from Freebird that you have made the Donation is required before I will ship the Kit out.
This kit is supplied with three 8-oz. bottles of Ride-On TPS tire sealant for motorcycles, installation instructions, dosage table, valve core removal tool, and installation hose. Each bottle contains enough Ride-On to treat an average motorcycle tire. Please refer to our dosage table for exact dosages required for your tire size. Ride-On Tire Protection System tire sealant (tyre sealant) for Motorcycles has been designed for use in high speed applications without causing vibrations. Ride-On TPS tire sealant for Motorcycles helps improve the tire balance, seals punctures from objects up to 1/4" (1/8" for tubes) in diameter, prevents flats and helps tires last longer. Ride-On TPS tire sealant for Motorcycles contains corrosion inhibitors that protect aluminum and steel wheels against rust. Ride-On also helps reduce dry rot and eliminate the tiny, invisible porosity leaks that cause tires to deflate over time. Ride-On TPS for Motorcycles saves you money by increasing tire life, reducing down time, and lowering road service calls.
Regards and respect........Boomer
I"ll take the ride on kit boomer I have sent the donation as requested:banana:
Sounds good. Please PM me your snail-mail addy.
As soon as Freebird confirms your donation I will head to the Post Office and mail the Kit to you.
Hey polecat.....The weather-guessers are saying that we have a fast moving clipper coming at us tonight (Tuesday) and will dumping a bit of snow on us beginning long before our Post Office opens tomorrow morning.
I'll do my best to get the package on its way to you but don't be surprised if it does not go out until Friday.
Regards.........Boomer
