capn eddie Posted December 19, 2008 #1 Posted December 19, 2008 Just got my seat back from rick and i must say i really like the way my seat turned out. I would tell everyone to get this mod. done to your seat , so again thank you rick you saved my butt and it thank's you also. :bowdown:
cecdoo Posted December 19, 2008 #2 Posted December 19, 2008 I have dealt with Rick before, you are rite he does a great job. What did you have done? 1st or 2nd gen seat? Curious minds?? Craig
BIG TOM Posted December 19, 2008 #3 Posted December 19, 2008 I SENT TWO SEATS TO RICK THIS PAST WEEK..ONE 2ND GEN AND ONE OFF A V- STAR 1100...GLAD TO HEAR YOUR PLEASED WITH HIS WORK..NOT THAT I HAD ANY DOUBTS...EVERYONE TALKS HIGHLY OF RICK AND HIS WORK...:clap2:
capn eddie Posted December 20, 2008 Author #4 Posted December 20, 2008 I have dealt with Rick before, you are rite he does a great job. What did you have done? 1st or 2nd gen seat? Curious minds?? Craig i had the seat on my 87 vr done, again rick did a great job
Rick Butler Posted December 20, 2008 #5 Posted December 20, 2008 Ed, Glad I could help you out. I haven't done many 1st gen seats lately, so it was good to get to work on one again. And for the rest of you folks with a 1st gen, even though the exteriors of the cover looks good (and most of them are), the interior layer is probably in pretty bad shape. If you notice the raised panels, they have a thin layer of foam covered by a sheet of heavy plastic that has been heat sealed to the cover bottom. After all of these years the layer of plastic has become brittle and is cracking away from the foam. And in most cases the thin layer of foam is also pulling away. So in this case, I remove the layer of plastic and most of the time the thin layer of deteriorating foam. But with a 1 1/2" layer of memory foam glued and shaped to the foundation foam, you now have a revived seat that will conform to the shape of your butt and will reduce pressure points. In fact I've already seen at least one RSV seat in just about this same condition. These standard RSV seats are designed in this same manner with panels with a thin layer of foam covered by a layer of heavy plastic sheet molded into each panel. This gives the cover that puffy look with each panel. There you have it, Rick
