wild hair 39 Posted December 18, 2008 #1 Posted December 18, 2008 this stuff realy works,took a little time to get it right,it's strong,and quick http://www.atlanticjetsports.com/plastic_repair_kit.htm and gose a long way
V7Goose Posted December 18, 2008 #2 Posted December 18, 2008 Which item were you using, the ThreeBond or the Plastex? Goose
relic Posted December 18, 2008 #3 Posted December 18, 2008 Plastex is the product that I have used and it worked great.I have repaired numerous things with it and it seems to be the only plastic repair product that does actually work.
wild hair 39 Posted December 19, 2008 Author #4 Posted December 19, 2008 i used the 59-9036,on deep cracks you need to,do two or three coats,i gave it 24 hrs to fully cure,can start working with it,in about 30 min
timgray Posted December 19, 2008 #5 Posted December 19, 2008 I found ABS pipe solvent to work fantastic. it's a slower cure time so you need to hold parts together, but when it dries it's welded the abs plastic back together. I had a mounting tab break off one of my fairing halves. Plastex did not hold it on more than a month. The ABS solvent held so strong that I discovered a new crack as it cracked there and not on the glue line. Although I did doscover it will not work if you tried another product first. you have to get all the other glue off and then clean it really good with the ABS solvent cleaner before it will melt the two pieces back together.
Jrichard Posted December 19, 2008 #6 Posted December 19, 2008 HEY LOWELL------------glad to hear ya still 'kicking'----------that stuff --------U did buy a 50 gal. barrel! didn't ya????????????------------lotta stuff to work on @ the salvadge yard{i.e. THE RED BARN"---------C ya----------J:sun1:
