StuD Posted December 17, 2008 Share #1 Posted December 17, 2008 I have the forks off a 82 XJ 650 & using a 8mm hex sosket on the bottom of the lower tube, and a 12mm hex socket with all my extentions down the upper tube, both seem to turn (spin) but will not loosen the dampning rod. Any ideas? Need to remove dampning rod to replace the fork seals. H E L P Thanks :canada: Link to comment Share on other sites More sharing options...
MiCarl Posted December 17, 2008 Share #2 Posted December 17, 2008 (edited) The damping rod is not hex, it's 12 point. You can hold it with a 19mm hex. I don't have a 19mm hex. The way I do XJ forks is to take a short 12mm bolt from my bin (it has a 19mm head). I put two nuts on it and jam them together to lock them onto the bolt. I then drop that assembly down the tube and hold it with a 19mm socket and a couple extensions. Edited December 18, 2008 by MiCarl Link to comment Share on other sites More sharing options...
rod Posted December 18, 2008 Share #3 Posted December 18, 2008 Same as a Virago. I use a similar method a MiCarl but welded the nuts to a long piece of rod and use the impact to remove. Rod Link to comment Share on other sites More sharing options...
5bikes Posted December 18, 2008 Share #4 Posted December 18, 2008 Just put a new fork seal on top of the old one cleaned up. Super glue it in around the outside edge. Lasts a lot longer too. Old one takes the punishment and lubricates the new one. Done in half the time! Link to comment Share on other sites More sharing options...
