Guest ray griffiths
i bought an 83 venture for parts and it turned out to be a great fixer upper. problem is that i don't have the keys to it. does anyone out there have the complete ignition set for a venture for sale. i need the main ignition, saddle bags, fuel cover, rear bag and dash compartmet ignition and key? Ray.
i might be wrong, as far as your year model goes, but on my '86, one key does it all!i would remove the ign. and take it to a locksmith. have him re-key it, or make a key that will work ,just like the original.
just jt
You may also want to check with your local Stealership and see if they can come up with a key using the VIN or something like that. I know it's been done before on other models as long as you can prove ownership...
  • 2 weeks later...
Guest ray griffiths
thanks guys, i did just that. took the main ignition to a locksmith and presto, a key for the whole bike.Ray.
Hey Ray,
I just ran across your post, and wish that I had caught it earlier. I also have an '83 VR, and would have been more than glad to have sent you a copy of my key. 'Glad that you got it straight anyway, though.
How easy was that?
All you gotta do is ask - - -
  • 2 weeks later...
Guest venture777
I wonder how much a locksmith might charge to make a key for your bike? that would probly be easier to find
if you take the ignition switch off the bike it has the key code ## on it and a locksmith could make one w/ that number:080402gudl_prv:
Yep... Here's what anyone in the future should look for....
