Guest allenluikart
Hello,
I am trying to track down the lack of turn signal on my 1991
I have checked all fuses and connections-the bike is almost skinless
should I consider replacing the signal relay?-its $130.00!!
The front "turn signal" lights are fine in a runny light condition-but no turn signal. The back siganl lights give me nothing-all bulbs are new
I worked hard all winter to get the bike painted and detailed-just bought it last year
BUT I can't ride in Cleveland Ohio without turnsignals
Your input would be greatly appreciated
Guest allenluikart
Muffinman
Fraid to say I didn't know I had emergentcy blinkers-I'll try em tomorrow night and let you know
Thank You
Allen
Allen if the emergency flashers work you will know that the wiring is ok to the lights if they work start with the turn signal switch before you spend big money on the flasher unit.
the emergency flasher switch is on the right side black top panel up near the instrument panel.
Jeff
You don't want to put in a $130 part w/o knowing it's bad. Trace the circuit on the wiring diagram, probe with a meter and sewing pin (to push thru the insulation) and find out where you lose power. In fact, the manual has a troubleshooting procedure which might help. I didn't look, but it might also have a procedure for checking out the flasher. Since it's all 4 lites, it could be the flasher, but also could be anywhere in the wiring up to the flasher.
Jeremy
Guest allenluikart
Gentlemen-what a great sight-put my emergentcy flashers on and all bulbs-front and back lit like a christmas tree!!!!!!!!!!!! Can't tell you how pleased I am
Now I need to look at my signal switch-do I take apart the hadlebar switch or is this a modulal up front (relay)
Please let me know -I can feel the wind in my face already
At least I can start putting together the back end!
THANKS
Al Luikart
Guest venture 777
I AGREE make sure the 4 way flasher is plugged in:080402gudl_prv:
