#1 Is the battery under the seat and how do you remove the seat? 2nd the manual said the dealer needs to charge the battery, is there something special about it that I can't put it on my Battery Tender also do you recommend removing the battery or just hooking tender up on bike. The dealer that I bought the bike from was not a load of info.
See pic to remove seat.....I always remove my battery and put it on a battery tender for the winter storage time. You can use a large pair or channel loc pliers to grip the battery to pull it up from the holder.
The battery is under the drivers seat. Two nuts towards the front, 10 mm secure the seat to the bike. Remove the nuts and lift the seat from the front portion exposing the battery. There is no reason you can't do any maintenance on the battery and add your battery tender.:thumbsup:
Yes the battery is under the drivers seat. This is removed by undoing the two nuts that hold them on. If you get down beside the bike and look under the seat you will see these about mid way.
The battery can be hooked up to a battery tender and many folks here have them. I am not sure if a battery tender is strong enough to charge a real low battery...one would think not but they are good for maintaining a charge.
A good strong battery is important and a bad one will make things go goofy in a hurry and with little warning.
The dealer (stealer) does not have to do this simpliest of maintenance. Heck there are many folk on this site that dont let the dealers near their bikes and do most things themselves.
This is a great site and you should visit the tech sections- the advice there will save you bundles of money and keep your baby purring along for many miles.
Hi Scott, :2cents:
I have a battery tender and I added the connector leads to the battery so I could plug it in and unplug it when needed. That way you don't have to take the seat off all the time. You can find the battery tenders or the extra cables at http://www.batterytender.com/.
Ride like this is your last day, :7_6_3[1]:
John
I do have a auto trickle charger and trickle charge my other car through the cigarette lighter plug. Can I also plug in my trickle charger via my Venture's 12V lighter plug?:confused:
You CANNOT trickle charge through power (lighter) port. It is disconnected with the key off. You can charge through the port if you leave the key in accessory but the radio would then be live.
Hi Scott, :2cents:
John
I to have the battery tender hooked up where I can just plug it in and not remove the seat. Still on the original battery starting my 9th year. I do think I will change it after Christmas just because I don't like surprises when I don't need them.
Where do you have the connector tucked away. This seems the way to go for ease if we get any surprise warm weather and I won't have to reprogram everything.
Been using a B-Tender on each bike I've owned, first thing I put on my ride. Make your connections tight to the battery and (I prefer) to have the connector on the left (stand side), tie wrapped the wire connector to the frame (about an inch or so from the end) to stop excess wire to wiggle out flip/flop in the wind against the chrome.
[ATTACH]23919[/ATTACH]
[ATTACH]23920[/ATTACH]
I ran the wire for the tender out the right side between the frame and the plastic behind the seat, then wire tied it to the top of the right side saddlebag guard.
I put mine under the right side cover, It fits in very well, and to hook up the battery tender, all you have to do is pull the cover off. One bolt, take 15 seconds. And. everything is oughta sight... :Venture:
Caution note here:
If you do remove your btattery to charge it, DO NOT set the battery on the cement floor ...place it on a piece of wood or something, but do not set it directly on the cement floor..it will drain it.
[quote=Eck;274640
Caution note here:
I know that this is a commonly held belief but with modern batteries, there is no possibility of leakage to damp concrete to discharge a battery. In the old days, battery cases were a hard molded rubber with high carbon content that could allow some leakage but this is not the case with the high dielectric value for today's polymer cases.
Keeping the battery charged is very important for the longevity of your battery. A battery tender is a good idea. I tend to just leave it in the bike and put it on a slow (500 ma) charge for a few hours every few weeks. No problems so far.
Ross
What if I keep the radio off and ignition on accessory, is this ok?
Ross
http://www.msgroup.org/forums/mtt/topic.asp?TOPIC_ID=6685
:rasberry:
Do yourself a favor and when you decide to replace your battery - replace it with the Odessey. I replaced mine last year when Condor headed up a group buy with the company. It may cost a couple dollars more but I think in the long run, it is worth it. My two cents.
MIKE aka Uturn
:7_6_3[1]:
What is good about the Odessey battery?
They are AGM, Dry Cell, Technology. ( ie. Mil. Spec. )
No fluid to Add.
They charge to 12.7 to 12.8 volts.
They put out about 3 times the Cranking Amps of a Lead Acid Battery.
They Last a Long Long Long Time.
They can be mounted in any postition except UPSIDE DOWN>
However they cost more, but are worth the extra money.
I have three of them in use, and absolutly no problems for 3 years.
http://www.odysseybatteries.com/ Check their website for complete specifications, and fitment guide.
:thumbsup:
  • 3 months later...
I put my battery tender lead out the right side and tie wrap along the frame so it is out of site but I can reach under the seat and hook it up. Easier on the right for me the way I park it in the gararge to get to.
