Hey guys, hope you all had a great week! :banana:
Did all the testing of components, cleaning cable ends, ETC, we discussed earlier last week. Everything checked out!
I tested the battery with a standard auto battery load tester, it tested good. SO, after everything else checked out, I took the battery to a friend that has a truck shop and put a 24 volt load test on it, the meter dropped to BAD in 2 seconds. He thought it was a intermittent short in the battery and it took the extra heat to finally burn it into?.?.?... :bang head:
What ever, I put in a Odessey PC 680 and it fired off like new again! Drove all over town and made several stops, NO problems!!
Battery Outfitters in Rogers, Arkansas is a dealer if anyone close to them ($95 out the door). Most dealers charge about $121 delivered to your door.
Thanks again for all the help on my problem!!!
Gary C
Ft Smith, Ark area
