CAZCO Posted November 16, 2008 #1 Posted November 16, 2008 Hey guys, hope you all had a great week! Did all the testing of components, cleaning cable ends, ETC, we discussed earlier last week. Everything checked out! I tested the battery with a standard auto battery load tester, it tested good. SO, after everything else checked out, I took the battery to a friend that has a truck shop and put a 24 volt load test on it, the meter dropped to BAD in 2 seconds. He thought it was a intermittent short in the battery and it took the extra heat to finally burn it into?.?.?... What ever, I put in a Odessey PC 680 and it fired off like new again! Drove all over town and made several stops, NO problems!! Battery Outfitters in Rogers, Arkansas is a dealer if anyone close to them ($95 out the door). Most dealers charge about $121 delivered to your door. Thanks again for all the help on my problem!!! Gary C Ft Smith, Ark area
bongobobny Posted November 16, 2008 #2 Posted November 16, 2008 You will also notice an improvement in hot starting with the Odessy! Glad things are going good again, now get out there and ride instead of reading this post!!!
