If so, I am in need of the "Low Fluid" magnetic reed switch assembly. I'm rebuilding a couple of them, and on one the O ring for the switch was "glued" on and I sort of destroyed the switch. The float is fine. If you have one, I can make use of it...
if so, i am in need of the "low fluid" magnetic reed switch assembly. I'm rebuilding a couple of them, and on one the o ring for the switch was "glued" on and i sort of destroyed the switch. The float is fine. If you have one, i can make use of it...
i got one. !
Pa rider.
