clay18 Posted June 30, 2007 #1 Posted June 30, 2007 When the bike is not running lauri and i can talk fine to each other, but when I start the bike lauri barley hear me and i can barley hear her along with alot of noise coming thought the headset its almost like hearing the coils on the bike talking thought the headset. I thought it was just my new headset and i try two diffrent ones with the same results. is there a filter to put somewhere to block that? Also i havent tuned it and not to sure how to do that i have a SWR meter a old one but should work fine. i been surffing the web would one of these power filters work http://www.premiere-electronics.net/store/powercords.html
muffinman Posted June 30, 2007 #2 Posted June 30, 2007 Clay get together with Lewis on the swr meter The Cb worked fine before the new headsets so I would think that maybe the headsets are the problem. Jeff
clay18 Posted June 30, 2007 Author #3 Posted June 30, 2007 Clay get together with Lewis on the swr meter The Cb worked fine before the new headsets so I would think that maybe the headsets are the problem. Jeff I tryed it with Charlene's helmet and the same problems
muffinman Posted June 30, 2007 #4 Posted June 30, 2007 Ok what did you do to the bike? You know the warranty is out on the repairs so now we get into your money for repairs.LOL
clay18 Posted June 30, 2007 Author #5 Posted June 30, 2007 I just read if i took the whip ant. off the back and i still have noise, it may need need to be grounded better. could i use a battery cable to ground the ant.
GeorgeS Posted June 30, 2007 #6 Posted June 30, 2007 OK, what exactly did you change, since the last time it was OK ? Just the helmet headsets ?? Or something else.
clay18 Posted July 1, 2007 Author #7 Posted July 1, 2007 nothen just got some headsets, but the same kind
Gearhead Posted July 2, 2007 #8 Posted July 2, 2007 Clay, I have questions: did you ever use the system before, or is this the first time? Does the problem exist in the Intercom system regardless of whether the radio or CB is on? Do you hear the noise when listening to the radio too? Does the noise intensify with RPM? Jeremy
