Guest Bar Posted November 13, 2008 Posted November 13, 2008 Not sure if i'm posting this in the right place, my appologies if so. I'm curious if anyone has removed the tour pack (trunk) and rear seat as a modification of look for a RSV. I'm thinking that it would totally change the styling and maybe improve the handling in the process. I think it would drastically improve the looks if there was only the rear fender showing, but still retain the bags. I think it would look very sharp. Anyone have done this, if so, much work involved, and do you have a picture? Many thanks, Bar:cool18:
M61A1MECH Posted November 13, 2008 Posted November 13, 2008 A fellow named Scott Baken over at Star Touring and Riding did that, looks pretty good. Try this link I think it will get you there. http://www.startouring.org/viewimage.aspx?id=3094
GoldVenturing Posted November 13, 2008 Posted November 13, 2008 I have wondered the same thin g after seeing a used HD (unknown model) with the removeable tour pack. It had quick connects for the speakers, and it looked SHARP. Anyone with info on how this mod was accomplished?
Guest Bar Posted November 13, 2008 Posted November 13, 2008 Thanks for the pic. That does look sharp. Any tips on the proceedure and cost, or what I need to buy first? Bar
SaltyDawg Posted November 13, 2008 Posted November 13, 2008 Oh look it's a Tour Deluxe. LOL I highly doubt it would handle any different with the trunk gone. I am wondering where he put the CB since he relocated the CB antenna.
Guest Saddletramp Posted November 13, 2008 Posted November 13, 2008 He put the CB in the left saddlebag.
Chinto Posted November 14, 2008 Posted November 14, 2008 Has anyone swapped the saddlebags from the TD to the V. I have always like the hard case leather wrapped saddlebags that is on the RSTD. Would the RSTD saddlebags fit on the RSV? Dave
Leland Posted November 14, 2008 Posted November 14, 2008 The RSTD ('05-'09) have the same saddlebags as the Venture. I think the Stratoliner and V-Star have the leather wrapped bags. Don't know if they fit.
PERM44 Posted November 15, 2008 Posted November 15, 2008 Bar, I have removed the trunk on mine. I have a few pix posted in my gallery. It wasn't very hard to do. The antenna mounts were the hardest things for me. I wanted to keep both the CB and the radio. I finally found a guy to machine the mounts from aluminum and I mounted them down low on the fender struts. I put the CB in the left saddlebag and velcroed it to the inside of the bag. Takes up very little room. I still have the original seats for long trips. It gives me a place to put a bag. I have another set of seats that are cut down quite a bit for shorter rides. I'm still looking at putting a one piece on, but I haven't worked out the mounts yet. If you remove the back seat, there are quite few wires that would need to be hidden somewhere. As far as the handling, it is like a completely different bike. It's amazing how much lighter the bike feels without that extra 30 lbs up there. BTW, I had put +/- 50K miles on the bike before I took the trunk off. I was OK before with the handling, but this made the bike so much better. I dont think I will ever put the trunk back on. You could go with the RSTD, but I really like the fairing look and the radios. If you do pull it, you will be really surprised how much lighter it feels. But, "whatever blows your dress up"...
Aimhigh Posted November 15, 2008 Posted November 15, 2008 Bar, I have removed the trunk on mine. I have a few pix posted in my gallery. It wasn't very hard to do. The antenna mounts were the hardest things for me. I wanted to keep both the CB and the radio. I finally found a guy to machine the mounts from aluminum and I mounted them down low on the fender struts. I put the CB in the left saddlebag and velcroed it to the inside of the bag. Takes up very little room. I still have the original seats for long trips. It gives me a place to put a bag. I have another set of seats that are cut down quite a bit for shorter rides. I'm still looking at putting a one piece on, but I haven't worked out the mounts yet. If you remove the back seat, there are quite few wires that would need to be hidden somewhere. As far as the handling, it is like a completely different bike. It's amazing how much lighter the bike feels without that extra 30 lbs up there. BTW, I had put +/- 50K miles on the bike before I took the trunk off. I was OK before with the handling, but this made the bike so much better. I dont think I will ever put the trunk back on. You could go with the RSTD, but I really like the fairing look and the radios. If you do pull it, you will be really surprised how much lighter it feels. But, "whatever blows your dress up"... Nice bike...what kind of seat do you have on it? It appears to lower the instep.(?)
PERM44 Posted November 15, 2008 Posted November 15, 2008 Both sets are original seats that I had modified. When I first got the bike, I had Butt Buffer cut down the sides and had them add some foam at the back and added a gel pad. I'm only 5' 7" and had a little trouble flat footing it and reaching the bars. The other seats I had cut down even more which puts me more "in" the bike. Not as comfortable for 5-600 mile days but it works fine for normal day trips. I think any good upholstery shop should be able to modify a seat the way you want.
Guest Bar Posted November 16, 2008 Posted November 16, 2008 Thanks PERM44 and all for the encouragement. The bike do look very sharp, and I'm glad to hear about the improved handling. Too bad we can't get some kind of "quick release" system so it would not be such a deal to change it back and forth. The trunk does come in handy sometimes. Best regards, Bar
