Riceburner30281 Posted November 6, 2008 #1 Posted November 6, 2008 My fathers 83 venture is fouling the right rear sparkplug and running poorly.. he thinks its the fuel pump.. I think he's nuts but nevertheless he wants a new one.. anybody got an Idea where one can be had?
cliffno350 Posted November 6, 2008 #2 Posted November 6, 2008 (edited) www.flatoutmotorcycles.com its on the airfilter page I'd try there and ebay Edited November 6, 2008 by cliffno350
93 venture Posted November 6, 2008 #3 Posted November 6, 2008 Fuel pump is not going to kill one plug or any of the plugs. no spark to that cylinder? Bad plug wire. Carbs out of sink Runs the choke too long float in carb sticking or set to high weak compression on that cylinder
Riceburner30281 Posted November 6, 2008 Author #4 Posted November 6, 2008 cliffno350 said: www.flatoutmotorcycles.com its on the airfilter page I'd try there and ebay can you post a "direct" link ?
Yammer Dan Posted November 6, 2008 #5 Posted November 6, 2008 Don't need fuel pump. Sea-=Foam it first. Check Diaphragm on that carb. Check plug wire.
Riceburner30281 Posted November 6, 2008 Author #6 Posted November 6, 2008 Yammer Dan said: Don't need fuel pump. Sea-=Foam it first. Check Diaphragm on that carb. Check plug wire. done there been that..
mbrood Posted November 6, 2008 #7 Posted November 6, 2008 The plug is fuel fouled? Wet or sooty? If so, lean down and push on the choke for that carb and make sure it's not hanging open a bit.
Gearhead Posted November 6, 2008 #8 Posted November 6, 2008 Zanotti has great prices on factory parts. I know this has been discussed before, so I may be redundant. You're right, not the fuel pump! I assume you've checked the fuel levels? It could be a leaky or saturated float that's heavy and barely floats, which can cause intermittent flooding. I've had it happen. I can't explain why the flooding was intermittent, but it was. After the second time stranded I found it. Jeremy
CrazyHorse Posted November 6, 2008 #9 Posted November 6, 2008 I actually had the jet tube unscrew and was only held in by the needle and was dumping fuel in copius amounts but I did not notice it at first because it sat in a normal looking position and happen to see it move when I reved the motor. Gas mileage was bad too in low 30's.
