If you find one I'd appreciate if you'd post the part number.
I'm pretty sure mine isn't stock since it's blue-white and not very bright.
Thanks.
There's a couple of brighter bulbs available as replacements for the MkI's. Ask the clerk for something a little more potent.... Can't remember the part number but the standard bulbs are fairly common....
OK mone of the best things you can do to get more light out of the MK1's (besides switching over to a Mk2 headlight assembly) is to paint the black rubber casing around the headlight white. You want to remove the rubber piece and remove the glass as well from the plastic frame and clean it really good with a degreasing cleaner, followed by a rinse with rubbing alcohol. Now get yourself a can of cheap gloss white enamal paint and give it a good coat or two. While you are waiting for the paint to dry, head to your local Wally World and buy yourself a 9004 (I think) Sylvania Silverstar or GE Nighthawk High Intensity halogen bulb.
The biggest change in light intensity will be from the white paint. Last time I checked, white reflects the full spectrum of light whereas black absorbs it...
I just wanted to throw in that any headlight bulb you buy NEEDS to be an H4 rated bulb. A regular 9003 automotive headlight bulb will fail prematurely due to vibration. The H4 bulbs have the larger diameter filament and will withstand the vibration of a motorcycle much better.
Ride Safe,
Earl
Has anyone had an issue with too much heat in there and wires and insulation melting??????I had a headlight plug begin to melt and I'm notsure whick headlight bulb might have done it. joe
I recently installed a Sylvania Silver Star. Very big improvement over my stock bulb. It was about $17 at Autozone. There's a thread in here with the part number.
I tried the Silver Star on my bike and my cars. It was an improvement, but I found them to have a short life in all the vehicles. I ended up putting a PIAA bulb in my bike and I had already upgraded from the MKI to the MKII system and that was a great improvement.
RandyA
