Freebird Posted October 27, 2008 Posted October 27, 2008 OK folks, I've heard a lot of complaints here about the search function on this forum. I have made a change that we can try out. The option to use the "Google" search in the drop down menu actually works very well. Just use that field and select "www.venturerider" and you will usually get good results. HOWEVER, I have also added Boolean search capabilities to the regular search. Some won't know what that is so let me give a simple example. If you enter 1999 RSV in the search box, it will search the site for every instance of 1999 and every instance of RSV. With Boolean enabled, you can use quotation marks around the term to better isolate the results. In other words, you would type "1999 RSV" in the box and now it will search for that exact term instead of any instance of either word. For those of you who are more advanced with this stuff: This permission allows Boolean searches, which includes the usage of AND, OR, and NOT to limit results. This option can be server intensive for very large forums so its usage is cautioned.
BuddyRich Posted October 27, 2008 Posted October 27, 2008 Oh great, I failed algebra, I thought the google worked great.
pegscraper Posted October 28, 2008 Posted October 28, 2008 The search always worked as an OR statement? I never figured that out, but good grief, no wonder it would bring up so many seemingly unrelated results. What do we use for the NOT?
Freebird Posted October 28, 2008 Author Posted October 28, 2008 There are a couple of ways you can do it. Let's say, for example, that you are seaching for a guy named James. You know though that his last name is not Smith. You would search for: James NOT Smith or James -Smith Here is a pretty good and easy to understand tutorial on Boolean search terms. http://www.learnwebskills.com/search/engines.html
Dano Posted October 28, 2008 Posted October 28, 2008 Thank you Professor Nelson!!! I always did like Boolean equations, they're the only algebra I understand!! Use it everyday in trouble shooting!! Works great in any situation, even if you don't know you're using it. Dan
Sleeperhawk Posted October 28, 2008 Posted October 28, 2008 I liked the Google search since you implemented. Just don't loose that option.
hillrider Posted October 29, 2008 Posted October 29, 2008 Only problem I have now is that the 'Google' option only shows up 10 percent of the time. Sometimes I can get to it by going into the advanced options, but not always.
Freebird Posted October 29, 2008 Author Posted October 29, 2008 hmmm....I can't explain that one. I have it hard coded into the program so it should be there all the time. UNLESS you are talking about on the home page or pages other than the forum. I only have it coded into the search drop down here at the forum. Hadn't thought about that before. I'll try to add it to the home page also.
hillrider Posted October 29, 2008 Posted October 29, 2008 You're right (as always). Once in a forum it works. From the forum home page is where I was having trouble.
kevin-vic-b.c. Posted October 29, 2008 Posted October 29, 2008 Freebird.... I have not had any complaints about this site it is just great. I may not use it as much or as often as some do, but, it is a great place to visit and check out what is going on. Thank you for all you do for us so we can have this site .............. Kevin ride safe all
spankym Posted October 29, 2008 Posted October 29, 2008 thanks for adding more features to what is already a great site
