Guest STARRIDER225 Posted October 27, 2008 #1 Posted October 27, 2008 Was told the r/s venture has a recall re: Steering?? Anyone know of this?
Rick Butler Posted October 27, 2008 #2 Posted October 27, 2008 Skip, The last time I heard of any problem with the steering head bearings was back in 83 and it was never a recall issue. Knowing the details of this component, I can't even imagine of factory recall. Now on the GL1800 and ST1300s I've heard of issues with the steering head bearings and some serious head shakes, but even then it has not turned into a recall. Hope this makes you feel better, Rick
N3FOL Posted November 9, 2008 #3 Posted November 9, 2008 There is another thread in the 2nd Gen section that talks about tightening the steering head. Lubricating the bearings may be a good preventative maintenance for these Ventures. When I reach 15K, I may tackle some of the lubrication points and let the shop deal with the harder parts of lubricating my Venture.
treeman Posted November 9, 2008 #4 Posted November 9, 2008 Just got mine out of shop/ tightening steering head. much better. Lub all points. new tires ( Avons ) it was my 16,000 Check up. Guys the streeing head ( Got to be TORQED
N3FOL Posted November 9, 2008 #5 Posted November 9, 2008 Did the shop just tightened your steering head or did they tightened and added grease to the bearings?
treeman Posted November 10, 2008 #6 Posted November 10, 2008 They Grease it to. Had front end off ground. Its real good now.
N3FOL Posted November 10, 2008 #7 Posted November 10, 2008 treeman, Could you describe how your steering felt before you had the bearings greased.
JerryK Posted December 1, 2008 #8 Posted December 1, 2008 I bet the biggest change was the titres......The Ventures feel like a different bike with the Avons JerryK
