Left turn signal doesn't seem to work when I apply the switch. When I apply the 4 way flasher all lights work. I assume that it means that I have a switch problem at the left handlebar control.
Iowa Guy
Squeeze is right but to answer your question yes, if the 4 ways work then the problem is most likely in the switch. The connector would be the best place to start...
Squeeze & Bongobobny,
Thanks for the reply. Indeed, left suddenly started working again. Guess that I need to check and clean those two connectors.
Thanks.
Iowa Guy
  • 3 months later...
Connection on the Handlebar-Switch or the Wireing Harness Connector might be bad, check and clean both and this will be gone.
Where do I locate the wiring harness connector?
Iowa Guy
Its fixed. I went out to the local dealer, described the problem to the mechanic there and watch as he respectfully but oh so obviously glanced at me with his - OMG, doesn't he know anything - look.
The answer: WD-40
Now I am carrying some in the side bag right along side the duc tape.
Iowa Guy
:thumbsup2:
