Silver Bullet Posted October 13, 2008 #1 Posted October 13, 2008 how do you tell a-h- basket from a -I - basket????
Silver Bullet Posted November 18, 2008 Author #3 Posted November 18, 2008 sorry it took so long to get back--the basket that I took out was supost to be a I basket. and I can't tell that it is'nt. but the only # on it is 26H01 t-3. these are the only # on the thing. so i'm wondering which one it is. I cant find any one who knows the # of the I basket ....so if any one who has an I basket happens to know the # , would you mind giveing it to me?? thanks jack:think:
BoomerCPO Posted November 18, 2008 #4 Posted November 18, 2008 I just dug this up....Hope it helps you. In addition to the normal replacement part, an "I" size primary driven gear is available (4XY-16150-09-00). The "I" size primary driven gear is not used in normal production. It was produced to reduce the normal gear whine noise the Venture engine emits and some customers find annoying. Installation of the "I" size primary driven gear results in slightly greater gear lash. We have found this additional lash, in some cases reduces gear whine noise or it may move the peak noise level to an rpm not normally used while cruising, either of which can be more acceptable to a customer.
SilvrT Posted November 18, 2008 #5 Posted November 18, 2008 I just dug this up....Hope it helps you. In addition to the normal replacement part, an "I" size primary driven gear is available (4XY-16150-09-00). The "I" size primary driven gear is not used in normal production. It was produced to reduce the normal gear whine noise the Venture engine emits and some customers find annoying. Installation of the "I" size primary driven gear results in slightly greater gear lash. We have found this additional lash, in some cases reduces gear whine noise or it may move the peak noise level to an rpm not normally used while cruising, either of which can be more acceptable to a customer. Interesting...verrrrrryyyy interesting... do U happen to have a web link for that?
BoomerCPO Posted November 18, 2008 #6 Posted November 18, 2008 Here ya go.....Sorry for the delay....I had to retrace my steps to find it.LOL! http://www.venturerider.org/forum/showpost.php?p=55625&postcount=43
Silver Bullet Posted November 18, 2008 Author #7 Posted November 18, 2008 (edited) thanx boomer!!! that is grrrrreat. now I know the one I have is not a I basket,, because that # is no where to be found on it. now I need a # for customer service at yamaha so I can fuss at them a little. ha ha ! a lot of good that would do. Edited November 18, 2008 by Silver Bullet
BoomerCPO Posted November 18, 2008 #8 Posted November 18, 2008 thanx boomer!!! that is grrrrreat. now I know the one I have is not a I basket,, because that # is no where to be found on it. now I need a # for custer service at yamaha so I can fuss at them a little. ha ha ! a lot of good that would do Well hopefully your Dealer is one of the "good ones" and will do the job over again for you using the right clutch basket! Good luck and ride safe! Boomer
Rick Butler Posted November 19, 2008 #9 Posted November 19, 2008 Guys, The alpha character is not stamped onto the back side of the primary driven gear, but scribed with a roto tool. Or whatever you would use to scribe your name on a tool. The difficult part is that you have to take the basket and gear out of the bike so you can see it on the back side of the gear. Hope this helps, Rick
