hdroyer Posted June 17, 2007 #1 Posted June 17, 2007 I took the rear wheel off to check the placement of the caliper bracket, the washer looked to be in the wrong place. The collar was missing, I sure could use one if any one has one they could part with it. Some one put a new tire on looks to have put no collar, caliper bracket, washer then forced the swing arm over to keep the wheel in place. I would like to know the order of the parts to put them back. Collar,Bracket,Washer.
GeorgeS Posted June 17, 2007 #2 Posted June 17, 2007 Service Manual is on this Web site: Or go to Yamaha main web site, Order parts section, look at the IPC it should show the parts, and the proper Order. You best do this, to make sure you have everything thats supposed to be there. The way you describe the last guy work on this, I would be wondering if Everything is even there.
