ok pinion is not working correctly. no plates on the bike right now and the pinion will bairly "wiggle" when i press on the lever as hard as i can i might add. how do i free up the pinion to move
Have you ever had the 'rods'... I like to call 'm rods... out? If you can get the lever to move using the bleeder valve and the rods aren't moving then I highly suspect the slave is bad. Or.... The reason I asked the first question is that there are two push rods and ball bearing between them that the slave, on the other side of the engine, pushes on. They have a rounded end and a flat end. The flat end goes against the ball. If you put them in with the round side against the ball they will bind.
I've not removed the "rods". so is the slave the portion that the bleeder valve is hooked onto? and would i need to replace it or could i simply clean it out? on the schematic the slave is the parts labled "27" right?
#27 is the Slave-Cylinder, right
I just did a bit Research about the Background of the Bike ...
http://www.venturerider.org/forum/showpost.php?p=93283&postcount=1
So, i think either the Mastercylinder ist stuck on it's Piston, or there was someone working on Clutch Years before and couldn't manage to get the so called Rod's (btw an outtake from the Yammi-Parts-List) and the Ball together. Maybe the Ball is missing.
If the Piston is stuck, i'm afraid to say, you have to dismount the Slave, order a Repair-Kit and get it fixed. There are some Guys who did this with Success. I personally haven't done that in the Past. If i remember right, at least GeorgeS has done that some Weeks ago.
Removing the slave cylinder is not difficult, even though it can be a little bit tricky to get out of the hole and back in again, but it will go. Just try not to break off the bolts holding it on and there is just two, I believe.
I think you are getting closer to getting it identified.
RandyA
So, i think either the Mastercylinder ist stuck on it's Piston, or there was someone working on Clutch Years before and couldn't manage to get the so called Rod's ( btw an outtake from the Yammi-Parts-List) and the Ball together. Maybe the Ball is missing.
I have rebuilt my slave in the past and it was a pain in the arse. Rebuilding the unit wasn't tough but getting it out was. A lot of folks on this forum have said that they just replaced theirs with a new slave as they aren't that expensive but if that is true it would be a first for Yamaha. The hard part is that the unit is held in place by two 5.5mm socket head screws and are lock-tighted in place. When you go to remove these two bolts be sure to clean the sockets well with carb cleaner, use a good, hard Allen wrench, and I put some Glover valve grinding compound onto the end of the wrench so as to stop it from slipping and rounding the Allen wrench, or worse, the socket head screw. Once the screws are out you have to keep playing with the slave to get it out as it only comes out one way and actually doesn't seem like it will. Rebuilding was simple if you have a brake cylinder hone to take the burnish off of the walls. Mine was filled up with dirt and sediment so that there was little movement of the piston. Made a huge difference in the clutch disengagement process once completed.
Dick
second Thought:
as the Seals in Slave are nearly Waste anyways, you could give 'brute Force' a Try. Use a 2x4 Piece of Wood as a Damper and give the Rod a slight!!!! Hit with the Hammer.
The Rod will go back in normal Place and probably not stuck anymore, even when you pull the Lever several Times to test the Moving. It's a Risk, no Question, but Life's a Risk also...
Can I remove the slave without takeing the trans cover off? or do i take that off to start then remove the slave? just looking for a few tips before i start messing with that side. could it simply be an easy fix such as cleaning it all out and putting it back together? or am I more likely going to be rebuilding the slave?
If it's just dirty it might be cleanable, but if it's ugly and rusted a new one runs around $70 bucks, and for the difference between new and a rebuild kit, new made more sense. When I replaced mine I bought the new one from www.buckeyeperformance.com.
Also don't discount that a previous owner may have asssembled the clutch wrong. ...PO's are notorious for doing that... It's what happened to me. I fianlly went back to ground zero and put it together by the book and It's worked great ever since. And ya gotta take the middle gear cover off.......
Once you have the Slave undone, it just makes no Sense to just clean it and put it back in Place.
A Repair-Kit or a new Unit would solve this for the next Years. If you just clean it, maybe you will find yourselves wrenching at it the next 4 Weeks, because it's leaking.
The left Side Cover has to be undone to get the Slave out.
Well one thing is for sure i did mess up a lil when I put the clutch back together the last time. I put the bolts back on like a car directly across from eachother and tighten them down not in a triangular patern. one question about the hit it and pray option... what are possible ramifications of this option? can I do more damage than is already done?
If you don't utilize the 10 Pounder giving it several hard Hits, there is nothing what could be hurt seriously. It's just to loosen the stuck Piston out of this Place.
As it had stuck the first Time, every time you pulled the Lever, the Piston was pressed more and more in this stucking Place. If you force it back to normal Place, there's a Chance of get it working normal again. Nobody knows how and why it did stuck, maybe it was just from some Misaligment in the Clutch-Assembly or whatever else.
Just hit it slightly, until the Rod moves a bit, then two or three even slighter Hits and it will be gone back to where it should be. If your not 100 Percent sure about the Line, open the Bleeder a bit, it will work as a second Damper and stop the Piston from crashing hard against the back of the Cylinder. First Damper would be the Fluid in Line.
As for the Bolt-Pattern ... that's not that bad. Bad would have been if you tightened the Bolts one by one clockwise or counterclockwise.
and ...
check the Rods and the Ball for existing in Place, if you're not sure that nobody tinkered around with the Parts
When you take that side cover off there is a washer on the bottom center Allen screw. It needs to go back in same place or you will have leak. I think there is a good chance you could break everything down and carefully clean it and get clutch to work. It may end up leaking and you would have to go back in but 2nd time is lot easier.
like a dumn a--lost the clutch in WIChITA,didn't even look at the flould,road it home,clean replaced with dot 4,off to atlanta,lost it again,this time i check the floud,real bad looking,mast have mosture in it,this time new dot 4,so far so good :080402gudl_prv:
WooHoo!!! it appears that the hit it with a hammer and hope for the best worked!
Congrats so far, hopefully this worked out for you fine, the next Days will tell you the Truth. If it's getting to leak, it will start the next Days. I'll keep my Fingers crossed.
How much Travel did you manage to get, when pressing the Lever ?
Everyone needs a good clutch hammer!!!
RandyA
Yeah, i second that ... :D :D :D
now I can squeeze it almost all the way to the grip. still feels nothing like the clutch on my 86 ninja 1000r so i'm not sure if i've got it right. wont know till i get a chance to take her down the street.
heres a good question how can one tell if the clutch plates are worn down to where they need replaceing?
Hi,
the Steel-Plates are checked for blue discoloring and for warping on a even Surface. The Plates are checked for warping and Thickness by measuring. Check the Manual for the correct Sizes. Even Surface could be a Pane of Glass.
I think, you need to go for a Ride and get all Things moved. After that, Decisions can be made.
I'm thinking i might just head down to the dealer and order the slave and a set of gaskets for both sides of the trany. i'm seening a small puddle of oil under the bike now. not sure if its hypralic fluid or oil but figure i just do it right for a change. I do need to get it going down the street to be sure its running ok anyway.
Guest timshosvt
My piston was sticky in the slave cylinder and would disengage but was sluggish. I flushed and bled without success. I took it apart and found rusty fluid inside that didn't come out with a vigorous bleeding and flushing session. I used a gray scotchbrite pad (000 steel wool, 800 grit wet sandpaper would work) and cleaned up the rusty piston and cleaned up the bore and unsuccessfully tried to reuse the seal. It leaked. I bought a new one for 11 something US dollars at www.zanottimotor.com
