Side cover oil leadk
Need your help!
Did a preventative stator change on my 89 VR getting ready for a 3000+ mile trip since the original stator had almost 60k miles on it and I run a lot of extra lights.
Installed the new stator (high output) in under two hours and was feeling really good about it until I got back from a 30 minute ride and had oil dripping from the kickstand.
The leak has definitively been isolated to the bottom most seam of the side cover (between the rearmost two bottom bolts) and is making a real mess.
Have changed the gasket now 3 times... once without sealant and twice more with two different types of sealant (yamalube, RTV gasket sealer) applied with no luck.
There are no cracks, scratches or dings, and both the side cover and case look square with a straight edge applied.
This bike was tight and dry until the cases were split... and as an old aircraft mechanic leaks drive me CRAZY!
Thinking about double gasketing... any other ideas?
Thanks in advance for your help!
:7_6_3[1]:
I doubt it is your gasket leaking. Most likely the rubber plug the stator wires go through. This is the most problematic oil sealing device on the entire bike. I personally get stressed out every time I have to re-install the stator cover because of that doggone plug. You are going to have to take it back apart and really clean the part of the cover that plug interfaces with. I mean really clean all the oil away not only from the surface of the cover but from the plug itself. I just installed the same stator and the wires that came with the new stator did not fit snuggly through the three holes in that plug. So rather than take a chance with relying on any kind of sealant to seal the holes where the wires fit through the plug, I used a couple layers of heat shrink over the wires so they would fit tightly. I then used ample amounts of high heat rtv gasket maker and no leaks. Give it a try.
Need your help!
:7_6_3[1]:
So how do you two like the stator? its the buckeye right? Master guns how long have you had it?
To be honest, I have had a hard time finding a difference. Before my last stator went Tango Uniform, my battery voltage at idle was usually around 13.65 now it around 13.85 or so. At 2000 rpms, it increases to just over 14.1 but that is with everything electrical on; high beam, two 35 watt driving lights, radio blaring, cb on, 6 front LEDs (WLED-5As wedge), 14 rear LEDs (WLED-Rs wedge), a white light LED license plate frame, the brake light on (also LED) and a 3.7 LED light bar on (3 on all the time and 7 more when brakes are activated). I purchased the highout stator, or what is proclaimed to be one anyway, from R&M Stator in Canada and so far, so good.
Thanks a lot for the suggestions... responding to more than one here...
Master Guns... The wires are dry... no seepage there. They were one of the first things I checked because of what I read on threads here.
Dano... I don't recall any of the bolts in the side cover having a copper washer like the one on the middle gear cover. I am pretty meticulous when it comes to disassembly and remember distinctively that the middle gear cover had one... but must have missed the side cover... cause I know it definitely ain't there now! Is it the same washer that the MG cover uses?
Three times--- New gasket each time.
Last time I finally Went over the surfaces with a Small Block of hard wood covered with 600 grit Emory cloth.
This time I used Permatex, Hi-Temp RTV Silicone Gasket Maker ( PX #82180 )
( Black Tube )
Instructions state to give it 24 hours to set up. And do not tighten bolts enough to cause the stuff to squeezs out.
The previous 3 Types of sealants, were setting up, before I could get the cover installed with ALL the Bolts properly torqued. I am estimateing it takes me about 45 min. to get both surfaces, covered with sealant, and the cover fully installed.
So the sealant was getting hard before the job was finished.
The above Stuff, ( #82180 permatex ) gave me over an hour to complete the job.
This was the 4th time I had re installed the cover, and finally got the leaking stopped !!
Anyway thats my 2 cents. Use new gasket, and the above permtex, and give it at least 24 hours before you re-install the Engine Oil.
Also be sure ALL oil is drained, and NO Oil on the surfaces, :witch_brew:
Michael. the copper washer, that dan spoke of, is for the very bottommost bolt.
in reality, is is a "drain plug", which allows the small amount of oil , trapped in the stator housing to be drained out into a container , before you remove the cover.without that copper washer, you will never stop your oil leak.
just jt
I can't find the copper washer that Dan and JT have mentioned in the parts manual... so I ordered one for the Middle Gear case bolt and will install it with the gasket sealer George recommended. All the parts are supposed to be in Friday... so I should be able to report out on a successful reinstall by the end of the weekend.
Thanks for all your help... frankly, if you guys suggested it, I would have been willing to dance around Old Blue with a sack of chicken bones around my neck if I thought it would cure this leak.
Just a thought.... If the leak still continues after all the great suggestions above, and the PO had previously used silicon to seal the cover, the metal surfaces might be suffering from silicon contamination. The first time around silicon works well as a sealant, but nothing sticks to silicon that has cured. Not even more silicon. It may be your problem??
It didn't appear that the PO had the cover off before... and the gasket appeared original with no sign of any sealant whatsoever... it came off clean from both surfaces. So, when I went back with that first new gasket, I put it on dry and torqued it down.
That copper washer theory still bugs me some... one because I know there wasn't one on there to begin with, and second because it isn't included in the parts manual. Please don't get me wrong... I am not doubting what at least two witness have shared at all... so I am definitely putting one on that lowest bolt position.
My theory: I suspect that the factory might have had some trouble with cases leaking at that bolt location during the assembly process, and used the copper washer as an "on-line" fix that never made it into the manual. Believe me, I've been around manufacturing operations for a number of decades and guys on the line are a amazingly creative bunch when it comes to saving themselves from grief... I was one of 'em for a while!
Did you torque the bolts to book specs when you used the sealant or something else?
Yes:-- But Don't go over. stay under a little, the let the stuff set up at least 24 hours with NO oil.
Do final torqueing the next day.
Also, what Condor Said, use emory cloth on both surfaces,
The microfiche shows the gasket on the middle gear cover... nothing for the main left cover.
Mine sure didn't have one. I used a THIN bead of yamabond4 on both sides of the gasket (used the pointy adapter off a tube of RTV and screwed it on the yamabond tube... and also REALLY cleaned and applied Yamabond on the wire holder blocks and around the wires... not much time but she isn't leaking a drop.
Edited by mbrood
Hey Props, The brass washer that everyone on this thread is talking about does not go on the stator cover. The brass washer is suppose to be placed on the middle bottom allen head on the MIDDLE GEAR cover. I have an 88 and my bud has an 83 and both have the brass washer. Also I used to have an 86 and ditto. Just my two cents. Great your rubber plug on the stator cover wasn't leaking. I hate that thing.
i had to replace my starter clutch assembly, a couple of months ago, and BELIEVE me, MINE had a copper washer.
don't know why some would and others wouldn't, but i can't make it disappear!:confused24::backinmyday:
lol
just jt
Maybe a previous owner or wrench put it on there by mistake????
Bottom Center bolt, of the AFT Cover left side. Its actually an Oil Drain.
After you Drain the oil, then take that bolt out, and you will get 2 or 3 more oz. of oil out of the Rear Section of the crank case.
But there will still be some oil in there.
If the Crush washer has never been replaced, good idea to get a new one.
If by AFT, you mean the small cover that covers the end of the gear assembly, there is no question about that cover having a drain and a bolt with a copper washer at the bottom hole. The statements here are about the bottom hole on the stator side cover having a drain hole and I do not believe it does. If it was not so late, I would go out in the garage and see if any of the tapped holes on the block have a drain.
RandyA
RandyA
This IS Correct !! None of the bolts of the Large, Forward, Stator Cover have a special crush washer. Only the Aft Cover. :thumbsup2:
Since I REALLY want this to be the last time I pull this cover off for a LONG time, I just want to be sure about how you applied the Permatex... did you apply it one or BOTH sides of the new gasket? If you applied it to only one side... which one?
She is all prepped awaiting the arrival of the new gasket... both mating surfaces have been hit with a block of 600 grit emory cloth and are, for the most part, as clean and smooth as a new baby's bottom...and have been wiped down several times with degreaser.
Thanks again for your patient support!
