Guest JGorom Posted September 29, 2008 #1 Posted September 29, 2008 Need to know what size/part number for 2nd Generation Speed Bleeders and how many of each for: 2nd Gen Brakes... 2nd Gen Clutch... Thanks in advance!!!
gunboat Posted September 29, 2008 #2 Posted September 29, 2008 hi you will need 2-sb7100 for the front calipers 2-sb8125 for the rear caliper and the clutch slave cylinder. i found out that you may or may not have to trim a little metal off the bottom of the left rear cylinder fin cover. the top of the speed bleeder is real close to cylinder fin. it helps to install the speedbleeder in the clutch cylinder if you remove the fin cover first. also keep the rubber square (dirt cover) that covers the oem bleeder you will see why when you get the speedbleeders. they come with there own rubber boots these are fine every where else but the clutch slave cylinder. feel free to contact me if you need any help. best requards don c.
Eck Posted September 30, 2008 #3 Posted September 30, 2008 Speed Bleeders: http://www.speedbleeder.com/ The SB8125 standard length ones fit the rear caliper and the clutch slave The SB7100's fit the front calipers Get 2 of the SB8125's and 2 of the SB7100's I paid $32 for all 4 shipped to my door.
Guest JGorom Posted September 30, 2008 #4 Posted September 30, 2008 BIG THANKS Don and Eck...I'll order these and next time I replace my fluids (just replaced) they will be a go.
