My engine oil level light has been coming on quite regularly until today, now it stays on. Oil is full as seen throught sight glass with bike on center stand on level ground.
I did an oil change 2 days ago and the light seemed to stay out for about an hour then came on again.
It never did last season.
Any answers to why or suggestions to fix this problem.
The warning light gets distracting and annoying.
Thanks
It could be nothing that a resolder job on the puter in the display wont fix. Thats all I can think of at this hour! Sorry. Maybe a sensor inside is not going up with the oil level?
You can allways put a sticker over the warning lite.:rotf::rotf::rotf::canada::canada::canada::rotf::rotf::rotf: I know, no real help..............
Hi,
first off all
make sure that there is enough Oil in the Engine.
second, check the Connection of the Sensor and measure the Signal it brings up
third
depending on either the Sensor is stuck somewhere, the SensorContakt isn't relasing or the Floater isn't floating anymore, take the Sensor out and check it out
fourth
if the Sensor Signal seems to bee good, there's can be a short in the Wires to the Display or the DisplayContacts need to be resoldered
