91nwl Posted September 24, 2008 #1 Posted September 24, 2008 The explanation of the volt meter function in the owners manual is pretty wimpy. It says if the needle drops into the yellow zone while riding, see your dealer. So, electrical experts; Can the meter show a weak or dying battery? Would that be indicated by a low reading while the bike is not running? If so, I assume less than 10 volts or so would be an indication of a weak battery? And, what if the reading is weak while riding? Is that a bad battery, or a bad stator?
GeorgeS Posted September 24, 2008 #2 Posted September 24, 2008 Basicly, it the Level of Voltage the Regultor is applying to the Battery, to Charge it. It should be 13.6 to 14.1. Use an Digital Volt/Ohm meter, to measure the Charging Voltage level. The Panel meter is really not accurate enough to measure the voltage.
Redneck Posted September 24, 2008 #3 Posted September 24, 2008 A volt meter tells the voltage in your electrical system. It can tell you the voltage is low in the battery with the engine not running but that will not tell you the battery is good or bad just current state of charge. with it running it will give you an indicator of your charging systems operation ether high or low a high reading (over 15 volts) would indicate a regulation problem. A low reading (below 12 volts) could indicate a regulation problem a generation problem or an over load problem from to much draw or a short. The volt meter is there so you can see if your system is operating properly if you understand how the system operates it can assist you with diagnosis of the problem. Are you really confused now?
Eck Posted September 24, 2008 #4 Posted September 24, 2008 Are you really confused now? Nope... not at all Redneck... In fact, I thought it was very well stated ...if you ask me..... Hell, couldnt have explained it any better myself.
Condor Posted September 24, 2008 #5 Posted September 24, 2008 Are you really confused now? Nope... not at all Redneck... In fact, I thought it was very well stated ...if you ask me..... Hell, couldnt have explained it any better myself. Yep, me too. Just one more thing. If a battery reads 10vdc it's basically deader than a doornail.
91nwl Posted September 24, 2008 Author #6 Posted September 24, 2008 Thanks. Good info. Pretty much what I thought, but good point about "current state of charge" versus "battery condition" with the motor off.
Squeeze Posted September 24, 2008 #7 Posted September 24, 2008 Thanks. Good info. Pretty much what I thought, but good point about "current state of charge" versus "battery condition" with the motor off. Actually, it's not the current State of Charge but the current System Voltage resulting out of the Rectifier making up DC Voltage and feeding Current into the System and the Battery taking up these Parameters minus the Current which is used by the Bike in the Moment. So the Voltage is just System Voltage nothing more or Less. It does NOT represent the Voltage which the Battery is charged with or the Voltage on the Battery in conjunction with the State of Charging. Of Course, as Redneck stated, the Voltmeter gives you an Indication of what's going on in the Moment.
MasterGuns Posted September 24, 2008 #9 Posted September 24, 2008 My doornail is reading "0" volts with my multimeter, just checked. And how Dead is a doornail???
a1bummer Posted September 24, 2008 #10 Posted September 24, 2008 I don't have any "doornails", all I have are "doorscrews". As far as being dead though... If ya look down on the molecular or even the atomic level, heck, even the sub atomic level where the quarks and gluons (and dozens more) are, There is a lot of stuff going on in there. LOL! I just can't help myself sometimes. Sorry.
5bikes Posted September 24, 2008 #11 Posted September 24, 2008 My gauge is accurate, but lacks divisions (gradulations, lines) Normal readings: Before starting, ignition on=about 12 volts Idle rpm=about 12.5 Over 2k rpm 13.5-13.8, just below the only line (14) Too high over 14 Lots of accessories will drop these #'s
bobcat Posted September 25, 2008 #12 Posted September 25, 2008 The explanation of the volt meter function in the owners manual is pretty wimpy. It says if the needle drops into the yellow zone while riding, see your dealer. So, electrical experts; Can the meter show a weak or dying battery? Would that be indicated by a low reading while the bike is not running? If so, I assume less than 10 volts or so would be an indication of a weak battery? And, what if the reading is weak while riding? Is that a bad battery, or a bad stator? Get a cheap hydrometer at any auto supply or battery shop...That will tell you the condition of every cell hence the overall condition of the battery....
