E-Fishin-C Posted September 24, 2008 Posted September 24, 2008 This fully loaded luxury touring machine comes with everything serious riders need, including a fourspeaker sound system/CB radio/intercom compatible sound system and a powerful and smooth V-four engine. There’s plenty of lockable storage in the form of a 15-gallon trunk and a pair of color-matched 9.3-gallon sidebags; that’s 33.6 gallons total. Ergonomically designed bucket-type seats with plush, wraparound passenger backrest for unbeatable long-range comfort. Industry’s premier rider support package includes a five-year, unlimited mileage warranty and 24-hour roadside assistance program. The Royal Star Venture S gets chrome accents to the front end. The Royal Star Venture achieves fuel economy up to an estimated 42 mpg** with a fuel tank that holds 6 gallons of gas. Engine: 79 cubic-inch liquid-cooled, V-four tuned to put out class-leading power — 97hp @ 6000 rpm and maximum torque at 89 ft.-lb. @ 4750 rpm — for incomparable touring performance. Four heated 32mm Mikuni carburetors with TPS deliver seamless throttle response and greater power across the entire rev range. Compact design, dual-intake system enhances performance without sacrificing fuel tank capacity. Large-capacity radiator ensures superior engine cooling for maximum efficiency. Single-axis internal counterbalancer reduces engine vibration. Wide-ratio, five-speed transmission with 5th-gear overdrive geared for both highway passing power and lower-rev cruising speeds. Low-maintenance hydralic clutch actuation and strong, low-maintenance shaft drive for touring convenience. Smooth, low-maintenance shaft drive. Four-into-two exhaust system puts out a throaty exhaust note and creates a long, low profile that’s easily customizable. Chassis/Suspension: High-integrity, single-backbone frame with solid engine mounting and 29-degree caster angle delivers quick, responsive steering and excellent handling. Class-leading long wheelbase (67.1-inches) provides exceptional roomy ergonomics for great rider control and comfort. Air-adjustable telescopic front fork designed with 29-degree caster angle and 5.5 inches of travel smoothes out the bumps and adjusts for varying load capacities. Air-adjustable link-type rear suspension features a vertically mounted single shock with 4.1 inches of travel for outstanding long-distance ride quality. Large-diameter front and rear disc brakes with sintered pads provide strong, linear stopping power. Wide, fork-mounted fairing, windshield, wind deflectors and frame-mounted lower cowlings offer outstanding weather protection. Full-sized floating-type rider and passenger floorboards reduce vibration and are positioned for optimal long-distance comfort. Additional Features: Incomparable fit and finish includes flawless paint with extensive chrome and brushed stainless steel accents as well as deep, valanced steel fenders. 6-gallon fuel tank with low-fuel warning light ensures outstanding long-distance touring range. Large, powerful 12V 60/55-watt remote-adjustable halogen headlight maximizes nighttime visibility and cuts a stylish profile. Cigarette type DC accessory connector in fairing plus 2-pin DC accessory connector under the seat. Ignition switch with integrated steering lock mounted to front of fuel tank for extra convenience. Vintage-style console and instrument panel features: digital speedometer, odometer, dual tripmeters, fuel tripmeter, clock, fuel gauge, cruise control, TPS self-diagnosis, speed sensor, and neutral, high beam, turn signals and low oil-level indicator lights. Electronic cruise control switch located on right handlebar controls for ease of use. Handlebar-mounted 40-channel CB radio with dual antenna for CB and AM/FM radio. Single-point audio control system for AM/FM radio, cassette, CD changer and intercom is MP3-compatible and headset-ready. Four-speaker (14 watts per channel) system with automatic, speed-regulated volume control to help hear over wind noise. Two-way rider/passenger intercom system. Huge, 15-gallon rear trunk with easy, one-touch opener can hold two full-faced helmets and includes a lined interior storage pouch. Color-matched hard-shell saddlebags each feature handy, one-touch openers and spacious 9.3-gallon storage with interior pouch. 12V 18AH maintenance-free battery ensures easy, reliable starting. http://www.starmotorcycles.com/assets/common/blank.gif
Squidley Posted September 24, 2008 Posted September 24, 2008 I know things take time to get to Canada Charlie....but we knew about that 3 weeks ago BTW I do LOVE the Raven and Seashell color combo, I actually would have taken it over my '08's color had I known
E-Fishin-C Posted September 24, 2008 Author Posted September 24, 2008 :nanner:I know things take time to get to Canada Charlie....but we knew about that 3 weeks ago BTW I do LOVE the Raven and Seashell color combo, I actually would have taken it over my '08's color had I known
BradT Posted September 24, 2008 Posted September 24, 2008 I know things take time to get to Canada Charlie.... Excuse me You should say takes a while to get too Garson, Not Canada. Brad
Squidley Posted September 24, 2008 Posted September 24, 2008 Excuse me You should say takes a while to get too Garson, Not Canada. Brad OK I stand corrected....perhaps the north pole would have been more appropriate
ventureblue Posted September 24, 2008 Posted September 24, 2008 class=featuretext>Single-point audio control system for AM/FM radio, cassette, CD changer and intercom is MP3-compatible and headset-ready. Four-speaker (14 watts per channel) system with automatic, speed-regulated volume control to help hear over wind noise. Yamaha needs to get with it. You cant even buy cassetes anymore! this is the year 2008 and not 1998.
Two Tone White Posted September 24, 2008 Posted September 24, 2008 ...and I was chastised for using one big head... but three big heads ought to call for some intervention or sanction. Maybe there ought to be a "Proper use of the Big Head" sticky.
