Storminyte Posted September 22, 2008 #1 Posted September 22, 2008 I got the lower vents for my '08 Venture and was looking to get highway pegs but it doesn't appear to me as if they will fit with the lower vents. Anyone have both on their bike?? Or know that only a particular peg will work with the vent?? Thanks... Dee:178:
Tom Posted September 22, 2008 #2 Posted September 22, 2008 I have them,they are thr kuraykn offset,i think called longhorns..although close they work great.
M61A1MECH Posted September 23, 2008 #3 Posted September 23, 2008 I have both, Kuryaken Longhorn offset part number 7980. Check out these pics on photobucket, th elowers are open but visible. http://i40.photobucket.com/albums/e224/royalsteve/2007VENTUREFOOTPEGS002-1.jpghttp://i40.photobucket.com/albums/e224/royalsteve/2007VENTUREFOOTPEGS001.jpg http://i40.photobucket.com/albums/e224/royalsteve/2007VENTUREFOOTPEGS002.jpg http://i40.photobucket.com/albums/e224/royalsteve/2007VENTUREFOOTPEGS003.jpg http://i40.photobucket.com/albums/e224/royalsteve/2007VENTUREFOOTPEGS004.jpg http://i40.photobucket.com/albums/e224/royalsteve/2007VENTUREFOOTPEGS005.jpg
JohnnyB Posted September 23, 2008 #4 Posted September 23, 2008 I have the offset hwy pegs also and love them. Johnnyb
Carbon_One Posted September 23, 2008 #5 Posted September 23, 2008 I've got the Kurykyan magnum Pilot offsets on my bike. Similar to the Longhorn models pictured above. I think they are a bit shorter in length than the Longhorns but find mine are just right for me. Have them adjusted so that the long arm just clears the vent with the vent fully open. Larry
ventureblue Posted September 23, 2008 #6 Posted September 23, 2008 M61A1MECH said: I have both, Kuryaken Longhorn offset part number 7980. Check out these pics on photobucket, th elowers are open but visible. http://i40.photobucket.com/albums/e224/royalsteve/2007VENTUREFOOTPEGS002-1.jpghttp://i40.photobucket.com/albums/e224/royalsteve/2007VENTUREFOOTPEGS001.jpg http://i40.photobucket.com/albums/e224/royalsteve/2007VENTUREFOOTPEGS002.jpg http://i40.photobucket.com/albums/e224/royalsteve/2007VENTUREFOOTPEGS003.jpg http://i40.photobucket.com/albums/e224/royalsteve/2007VENTUREFOOTPEGS004.jpg http://i40.photobucket.com/albums/e224/royalsteve/2007VENTUREFOOTPEGS005.jpg how well do the vent work in the winter? do they deflect a lot of air off of your legs?
george_park Posted September 23, 2008 #7 Posted September 23, 2008 I have the Kuryakyn Longhorn Offset Dually Highway Pegs with the 1" clamps mounted to the lower engine guards. They are the # 7980 in kit form (1" clamps, mounts, pegs). http://www.kuryakyn.com/products.asp?bn=metric&ci=3260 The way most people mount their pegs - with the "bump" for the bolt facing their foot (the bolt and nut to the inside facing the shift/brake) - causes me to hit the footpeg mount when I'm shifting which drives me nuts. I'll post a picture at some point. I moved the mount so that the bolt is on the outside, the footpegs up and forward of the bars. This way only the thin part of the clamp is towards my foot. You just have to make sure that the bolt/nut won't chew into the lowers by rotating them slightly which actually works well for your feet. Aside from the fact that I think I am going to bend the heck out of the guards (they are not the stongest) it really helps get your feet away from the main heating unit. Regards, gp
harlo9 Posted September 23, 2008 #8 Posted September 23, 2008 I have found that the vents are only noticeably useful when riding in high temperatures. Air can be deflected inward toward the engine. In the cold they make very little difference. My Kury Longhorns did interfere for my leg length. If my legs were an inch longer or shorter there would not have been a problem. So... I notched the vent. I cut a 1 inch diameter notch about a half inch deep into the lexan using a dremel then sanded edge to match the rest. Now the vents open all the way and it looks fine to me. I can post pics if you like but I've got to be off to work.
tford Posted September 27, 2008 #9 Posted September 27, 2008 I just installed the Kurykyan 4509,s. They mount on the horizontal engine guards. You have to take the covers off of you bike and do a little bit of grinding but they worked out great and they don,t stick out past the bike to far like some of the others that I have seen. Hope this helps. Terry
