Stoutman Posted October 1, 2008 Share #26 Posted October 1, 2008 (edited) Lone Eagle, I had the signal dynamics voltmeter on my RSTD until Eureka Springs when it went south. It had operated within spec, giving me a green light with the running lights on. Then at Eureka Springs it started going out. I thought at first it was my charging system, but when I got home that checked out. I hooked up a good digital voltmeter and it said I had 13.6 volts at 2000 RPM and 13.8 volts at 3000 RPM. all the while the Signal dynamics meter told me I was at 10 volts or less. A few days later the Signal Dynamics meter quit altogether. I checked the connections on the Signal Dynamics meter and they checked out OK. I just took the meter off the bike. I was looking at the Kisan Charge guard as a replacement. Maybe for Christmas. I like that freeze warning (like it ever freezes in Texas). Edited October 1, 2008 by Stoutman Link to comment Share on other sites More sharing options...
1BigDog Posted October 1, 2008 Author Share #27 Posted October 1, 2008 Lone Eagle, I had the signal dymanmics voltmeter on my RSTD until Eureka Springs when it went south. It had operated within spec, giving me a green light with the running lights on. Then at Eureka Springs it started going out. I thought at first it was my charging system, but when I got home that checked out. I hooked up a good digital voltmeter and it said I had 13.6 volts at 2000 RPM and 13.8 volts at 3000 RPM. all the while the Signal dynamics meter told me I was at 10 volts or less. A few days later the Signal Dynamics meter quit altogether. I checked the connections on the Signal Dynamics meter and they checked out OK. I just took the meter off the bike. I was looking at the Kisan Charge guard as a replacement. Maybe for Christmas. I like that freeze warning (like it ever freezes in Texas). You mean I did all that work for nothing???:rotfl: Actually, im finding the Signal Dynamics LED light a bit too touchy for my tastes. I like the way the Kisan works, especially the number readout. That Kisan sure is pricey, though..... Link to comment Share on other sites More sharing options...
Lone Eagle Posted October 1, 2008 Share #28 Posted October 1, 2008 Wow, thanks guys - this will definitely be a project here coming up in a couple of months with some things to consider. Appreciate the feedback. Link to comment Share on other sites More sharing options...
