Dieseldawg Posted September 14, 2008 #1 Posted September 14, 2008 Where is the fuse located at for the 12volt accessary plug on the left inside fairing?Also what amp is the fuse?
SaltyDawg Posted September 14, 2008 #2 Posted September 14, 2008 There are two locations for fuse blocks. One is right behind the left battery cover and the other is behind the right lower fairing. The amps will be on the fuse.
Dieseldawg Posted September 14, 2008 Author #3 Posted September 14, 2008 Thanks for the help.I thought that it might be behind the right fairing.Thats where it was.
sarges46 Posted September 15, 2008 #4 Posted September 15, 2008 And its a 5 amp. Had mine blow in Kitchner because I was using a air pump to blow up air mattresses. Funny thing....the acc. plug I put on the wifes vstar didnt blow under the load.
ediddy Posted September 15, 2008 #5 Posted September 15, 2008 I can't use my cycle pump with the acc plug. It blows the fuse. I have to take off the seat and use the battery clamps to hook my cycle pump to the battery.
