Guest spyder66 Posted June 6, 2007 #1 Posted June 6, 2007 well got the carbs put back togther, we tried to sync them, did the left 2 carbs first, went fine, then did the other side, soon as I started the bike she sucked the mercury out of the manometer, I never did like the thing, but now where would the mercury end up, in the carbs?, mabye drop the oil? Now I am going to jcwhitney to buy some vacume guages.
Condor Posted June 6, 2007 #2 Posted June 6, 2007 well got the carbs put back togther, we tried to sync them, did the left 2 carbs first, went fine, then did the other side, soon as I started the bike she sucked the mercury out of the manometer, I never did like the thing, but now where would the mercury end up, in the carbs?, mabye drop the oil? Now I am going to jcwhitney to buy some vacume guages. I've read about a few others that that's happened to. The first time I used the CARB II the rods almost went through roof on the right side. At the time I thought about the mercury stories and was glad they were rods...
Denden Posted June 6, 2007 #3 Posted June 6, 2007 In the instructions that I got with my Motion-Pro mercury sticks many years ago, it said that if the motor sucked in the mercury, the best thing to do is go for about a 20 mile ride right away. But the "why" this instruction brings up...I dunno.
Venturous Randy Posted June 7, 2007 #4 Posted June 7, 2007 Friday I should have a big jar of it. I needed it after doing the same thing trying to sync a friends Venture. Before I could turn the engine off, it sucked two tubes dry. RandyA
Guest spyder66 Posted June 7, 2007 #5 Posted June 7, 2007 So on yours do ya know where it went, carbs or down in the intake/ combustion chamber/ crankcase? How did you get it out? I ran mine for a few minutes after it happened and it didnt seem to do anything different. BTW where did you get the replacement mercury?
