BuddyRich Posted April 9, 2007 Share #1 Posted April 9, 2007 Your Carbtune may need to be cleaned from time to time. The reason is there is small gap in the case that will let dirt and dust in. Looking at the first pic and you can see the gap. How to clean it. First lets understand that it is IMPORTANT that you work on a flat surface and that you keep each rod and spring in its current cylinder. DO NOT MIX THEM UP. Do only 1 at a time. First you will need a small philips head screwdriver. 1. Remove the 2 screws on the bottom of the unit. 2. Carefully remove the cover 3. Carefully remove the foam filler. 4. Slide the cover down and off(says Carbtune on it). 5. Now remove one rod and spring at a time. Clean the rod with a lint free cloth and blow the cylinder out with air pressure. Now put it all back together and the rods should be moving freely again. Link to comment Share on other sites More sharing options...
